Page 1 of 2
KPro Red Board with D1 flashing
Posted: Mon Mar 04, 2019 6:04 am
by 7rrivera7
#not legible (pic attached)
Customer gave me his Kpro red board installed in a PNF-A13 ECU stating it won't start and has the D1 led flashing red.
I am going to try to connect, erase and reprogram but I wanted to see what this LED means. Tks.
Re: KPro Red Board with D1 flashing
Posted: Mon Mar 04, 2019 11:06 am
nothing attached.
We need the serial number as well as the version of software that is being used from help, About.
Posted: Tue Mar 05, 2019 5:34 am
by 7rrivera7
Kpro v3 #10877
KManager v4.3.6
I downloaded the customers calibration and the KManager tables reflected this.
I re-uploaded but it doesn't seem to do anything.
Kmanager recognizes the PRB w/KPRO but does not start - flashing red D1 LED
I erased the ECU (cleared security)
I created a new calibration and uploaded it but it doesn't seem to apply
The red LED still flashes and the car only cranks.
Posted: Tue Mar 05, 2019 6:09 am
by 7rrivera7
Pic
Posted: Tue Mar 05, 2019 11:30 am
Is the immobilizer enabled or disabled?
Is this the original ECU from the vehicle?
Posted: Mon Mar 11, 2019 3:55 am
by 7rrivera7
I connected to the ECU, downloaded the calibration and the Immobilizer not checked (disabled)
I am testing the ECU in my RSX which has a working KPro with the immobilizer disabled so no, it's not in the original car.
Posted: Mon Mar 11, 2019 10:19 am
Try going to the online menu and clicking on erase ECU. When that finishes, close the program and reopen it and then try uploading the calibration again making sure that the immobilizer is disabled.
Posted: Tue Mar 12, 2019 5:22 am
by 7rrivera7
1) Erased ECU
2) Closed KManager
3) Key to OFF
4) Waited 5 mins
5) Key to ACC
6) Load Kmanager
7) Create calibration
8) Immobilizer OFF
9) Upload to ECU
10) Blinking ref LED
11) Only cranks
Posted: Tue Mar 12, 2019 9:20 am
When was the last time this vehicle started and ran normally? Has the ECU been tried in a known running vehicle?
Posted: Wed Mar 13, 2019 6:25 pm
by 7rrivera7
This is what the customer told me:
Car was running fine and suddenly lit the CE with code for knock sensor. He tried connecting to his ECU and was asked for a password which he did not have. He called his tuner who suggested erasing the ECU and upload the calibration again and that's when it stopped/failed.
Sorry for the vague explanation but I'm texting the client and it's difficult getting details...
Posted: Thu Mar 14, 2019 9:09 am
If he does not know the password he will need to go to the registered owner tab and click on the forgot password button and it will email it to the registered owner.
Posted: Thu Mar 14, 2019 11:09 am
by 7rrivera7
I understand we are past the password issue as I can connect and upload a new cal but the LED still blinks red. Remember, the ECU has been erased several times already.
Posted: Thu Mar 14, 2019 11:18 am
With everything plugged in and the ignition in the on position, go to the Help menu and click on "send information to Hondata support". Include a detailed description of the problem.
Posted: Fri Mar 15, 2019 4:04 am
by 7rrivera7
Good morning I just sent the information. Please confirm reception. Thank you Spunkster.
Posted: Wed Mar 20, 2019 8:30 am
by 7rrivera7
Hello any updates?
