**ALERT** 2018 Civic Si with latest software Boost By Gear is not working correctly....
Civic 2016+ 1.5 Turbo
gtfrede07
Post by gtfrede07 »
Edit: software version that has the issue is 3.2.4
Just letting you guys know that on 2 seperate tunes that I have tried to use boost by gear with have not worked correctly. If I want to limit my 4-6th gears below 3k it doesnt allow it to exceed what ever value is in the 0-3k boxes even at 5k rpm. The RPM deviation within each gear column doesnt work. Basically it only should have 6 individual boxes because each gear uses whatever the lowest value target is in the column. Hope this makes sense and please someone respond that they read this.
Re: **ALERT** 2018 Civic Si with latest software Boost By Gear is not working correctly....
Post your calibration as well as a datalog showing the issue.
gtfrede07
Post by gtfrede07 »
At work currently but will do as soon as I can
gtfrede07
Post by gtfrede07 »
If possible could one of the admin change the title to 3.2.4 instead of "latest software"
I shouldnt have worded the title that way for searchs later on
Have you tried 3.2.5?
gtfrede07
Post by gtfrede07 »
No sir but I will try it after I get the issue logged for you guys and let you know.
