Kpro V4 Nitrous cuts out
Posted: Mon Feb 25, 2019 1:15 pm
by RofromNorCal
ive upload the most recent tune for the Nitrous tune as well as the datalog
my issue is that when id do pull with bottle on or off with also the Arming switch on that i see the command (arming) and output to shut off and on
ive also had issues of the output to turn on the Nitrous on when arming is on, ive clear the ecu, upload a stock cal. found no change
play around my parameters unit ive just started to jump from Aux 1 to 2 then 2 stop working to finally
Aux 3 to get it to work that is when ive seen that the
Command and arming are just shuting on and off, as well as a bump on air/fuel to lean spot
it only happen (lean spot) when the bottle is on. making me think it cause by the Arming and command to be shutting on and off
this the 2nd issue ive had issue with the AUX setting not working correct on Kpro.
keep in mind ive over look the Parameters as well seeing if it is falling outside, ive found none at this time.
yes ive wire it just how you have it and gone threw wire both times, ive even move pins around to see any changes.
Re: Kpro V4 Nitrous cuts out
Posted: Mon Feb 25, 2019 2:34 pm
Do you still have the wire for the arming input (PSP E16) connected to the original location or has this been cut?
Posted: Mon Feb 25, 2019 7:18 pm
by RofromNorCal
Yes I have arming to e16
And command the relay on on e21
Straight wire and new ecu pin to ecu
For both sides
Posted: Tue Feb 26, 2019 11:09 am
Check your wiring or the switch you are using as the arming input is going off and on and this could be from vibration.
