Engine misfire
Civic 2016+ 1.5 Turbo
liaoyuan12580
Engine misfire
Post by liaoyuan12580 »
I use + 6psi program. When the weather is very cold. Engine temperature is very low. My Engine misfire. I asked for help. Thank you very much.
Re: Engine misfire
Can you post your calibration as well as a datalog showing the problem?
liaoyuan12580
Re: Engine misfire
Spunkster wrote: Fri Feb 22, 2019 10:46 am Can you post your calibration as well as a datalog showing the problem?
I don't have any fault codes.
liaoyuan12580
Re: Engine misfire
It lost power and I had to restart it.
ElpacoSV
Re: Engine misfire
Post by ElpacoSV »
Hi everyone, I'm getting the same issue. I'm running the +6base map as well. I only use Shell 91. I tried getting back to stock to see if it was Hondata issue and...I got the misfire code as well.
What I notice is that is only when is cold and humid...I check spark plugs and coils and they are fine. Injection perhaps? How long of data acquisition do you need?
Re: Engine misfire
long enough to show the issue
ElpacoSV
Re: Engine misfire
Post by ElpacoSV »
data is available: https://we.tl/t-NyzoCr1BZC
let me konow if you have it!
ElpacoSV
Re: Engine misfire
Post by ElpacoSV »
Any news?
Syntek
Re: Engine misfire
Post by Syntek »
Hi guys,
Had a similar issue in cold environments. Have a read:
https://www.civicx.com/threads/p0301-mi ... r-1.14271/
TL;DR, had faulty injectors and had them warrantied out.
Re: Engine misfire
Can you please attach your calibration and a Datalog to your post here?
ElpacoSV
Re: Engine misfire
Post by ElpacoSV »
Already did :-) datalog can be accessed by WeTransfer. File is too large to be attached here.
Re: Engine misfire
You can trim the Datalog down to make it much shorter and much smaller file by right clicking and selecting a start and end point then saving the Datalog with a new name. You must also include the calibration. Please post them here.
ElpacoSV
Re: Engine misfire
Post by ElpacoSV »
hope this help. I'm using calibration Hatch Manual, but my car is a Sport Manual. I don't know if this can affect anything...
Re: Engine misfire
Please post the calibration used to record the Datalog.
ElpacoSV
Re: Engine misfire
Post by ElpacoSV »
2017 civic Hatch MT +6PSI high octane
Rev hang = OFF
