Scalar & Offset help 4bar map sensor
Posted: Sat Feb 02, 2019 10:55 am
by bmarker
I tried adding a flea bay 4bar map sensor and thought I did my math correctly, but might be missing something. Here are the specs according to the map sensor manufacturer. 0.5v @ 50kpa - 4.80v @ 400kpa
My math:
400kpa = 4000mbar
Voltage range = 4.3V, pressure range = 4000 mbar.
scalar = 930.23
offset = -465.11
The result if very chunky idle and obviously not correct.
I also tried
voltage range = 4.3, pressure range = 3500 (from the 50kpa)
scalar = 813.95
offset -406.97
The result is an good start, but after 5 seconds, trips a map sensor error code and goes chunky idle.
Any advise on what I'm missing?
Re: Scalar & Offset help 4bar map sensor
Posted: Mon Feb 04, 2019 11:07 am
It sounds like the sensor may not work properly (cannot read vacuum properly). You might try returning it and purchasing a Hondata 4BAR MAP sensor.
Posted: Sun Feb 17, 2019 1:58 pm
by linkdeezie
what about the scalar for the omnipower 3 bar map sensors?
Posted: Mon Feb 18, 2019 11:08 am
You should be able to get that from OpmniPower.
