Kpro v4 Analog input problem
Posted: Tue Jan 22, 2019 7:20 pm
by Garrett_si
Hi, I have a K24 engine, I use a AEM 0-150psi pressure sensor on input Analog 0
The display in psi was working a few week ago when I calibrate it, but now I see over 800psi in the display.
I verify the input voltage but changing the Sensor setting from Pressure to Raw voltage, and input voltage still fine.
I attached files and calibration + screen shot
Re: Kpro v4 Analog input problem
Posted: Tue Jan 22, 2019 7:30 pm
by Garrett_si
Here is the files and screen shots
Posted: Wed Jan 23, 2019 10:21 am
Post datalogs that show the issue. Screenshots are not enough.
Posted: Thu Jan 24, 2019 11:19 am
by Garrett_si
Here is the datalog file
Posted: Thu Jan 24, 2019 12:01 pm
That is your calibration and not a datalog.
Posted: Fri Jan 25, 2019 10:38 am
by Garrett_si
sorry
here is the log
Posted: Sat Jan 26, 2019 3:42 pm
by Garrett_si
here is the log
Posted: Wed May 08, 2019 2:46 am
by Garrett_si
Did you see something wrong?
Posted: Wed May 08, 2019 10:27 am
What oil pressure sensor are you using?
Can you post a Datalog that shows the raw voltage?
Posted: Fri May 10, 2019 3:55 am
by Garrett_si
Sensor is honeywell 0-150psi
Raw voltage could be seen is Hondata software allow it like other standalone I think it's a necessity
