Vtec activation problem
theo57
Post by theo57 »
Hello hondata
Sorry in advance for my bad english i am french :)
I have a civic Fn2 with k20z4, flashpro,RH,catback cai etc etc
I have a problem with my vtec since 2/3 weekend,maybe after modification on my calibration or upload calibration i dont know really.
I turn on engine (cold start) ,warm up,drive and vtec no engage!
I turn off engine,turn on directly and now vtec work
Its the same problem for each cold start.
Do you have already a same problem?
Thank you
Re: Vtec activation problem
Can you post your calibration and datalogs showing it not working when it should be and then a datalog after resetting the ignition.
Also from Help, About, what is the version of software that you are using?
theo57
Post by theo57 »
Hello,ok i try to take this today
Thank you
theo57
Post by theo57 »
Hello,my calibration and data with no vtec activation and with vtec work
Thank you
Do you have a calibration before you made changes that does work?
theo57
Post by theo57 »
Ohh no i don t know at what moment the bug come
I realise test when the weather is good with my other calibration
theo57
Post by theo57 »
I use the software version 3.1.8 of november 2018 i believe
theo57
Post by theo57 »
In last week i try to change RPM vtec, température activation,km/h activation,disabled engine oil level,create new calibration and include my all parameters,no result
Oil level and pressure are good,its strange when i turn off,turn on, vtec work good no??
The ecu take an info and work corretly?
Are you using live tuning?
theo57
Post by theo57 »
Hello, no i don t use live tuning for the moment
Does the problem persist if you go to new calibration and start with a new calibration?
theo57
Post by theo57 »
Yes same problem with start new calibration with my parameters fuel,ignition,came etc
Do you want i test with just new calibration gruppe n for exemple ??
theo57
Post by theo57 »
Hello,today i download the new version of firmware and the flashpro will not upgraded corretly 😒
It stays with the flashing power LED
What should I do to allow the flashpro to update correctly?
Thank you
theo57
Post by theo57 »
After 3 trials its ok,I was worried about having another problem.
theo57
Post by theo57 »
Hello i try with other calibration and vtec work directly 🤔
