Hi
Need a base map for the following setup
Car- Civic 1996
Engine - k20a type R JDM
Short Intake custom 3 inch
Fuel rail k-tuned
Injectors- 310cc stock
Fuel- 91 octane
Fuel pump- Walbro 255LPH
Header- k-tuned swap header
Exhaust - 76mm skunk 2 mega power
Thank you in advance
K20a typer JDM base Map
Re: K20a typer JDM base Map
did you ever get this?
BrianJewell1988
There is a base map provided by HONDATA for very close to this exact setup.
Under PRB->RSX Type S->"k20a-itr"
This is a dyno tuned JDM DC5R K20A map for a car with the usual I/H/E. Depending on if your running an RBC/RRC, etc ypu may be able to squeeze a bit more top end or midrange out of it but it's a very good starting point.
1990 R32 GTR:Nitto 3.2L,7675 G2 SM,PPG,Hypertune,ARC,Nismo&other bankrupt-esque brands 1081AWHP@44psi on E98
2005 RSX Type S:DC5R K20A,Ported RBC/70mmTB,Injen CAI,GearX 1-4,Quaife 2 way,5.06 Gears,TL-S Brembo's, Wilwood Rear BBK,Fortune Auto 510's,etc
Hey, i am looking for that as well. But i couldnt find the calibration in the vault you mentioned.BrianJewell1988 wrote: Sat Oct 17, 2020 9:41 am There is a base map provided by HONDATA for very close to this exact setup.
Would you kindly upload it somewhere? Thanks!
