hondata red light
Dfurka50
hondata red light
Post by Dfurka50 »
ive been having problems with ecu or harness. the harness is a wireworx harness. I sent both out to get looked at and both places said they worked fine. I put in them in back in the car. it worked good and the next day the ecu is blinking red and I get same crazy numbers on the display window with the car off and the numbers don't change with the car started. these are the same numbers i got before.
tps -13
map -29.9
ect 302f
iat 302f
Re: hondata red light
Has J12 been cut on the ECU?
Dfurka50
Post by Dfurka50 »
j12 has been cut out. verison is 2.6.7. Ill have to get the serial number.,
