s300 Lambda overlay blank HELP
Posted: Thu Oct 25, 2018 3:23 pm
by g0sammo
So my lambda overlay is blank when dataloging. The cells are highlighting and following the map, but the AFR values do not populate. I have checked the settings in options, and tried both the sensor overlay 1, lambda, and tried sensor overlay 2, set to sensor AF. I have an AEM wideband wired to D14, and if i pull up the sensor list, the o2 sensor shows the correct voltage from the wideband. Also if i open the app on my phone through bluetooth, it displays the AFR correctly. Any help is greatly appreciated!!!!
humble tune plus mods 10-23.skl
Re: s300 Lambda overlay blank HELP
Posted: Thu Oct 25, 2018 7:17 pm
by g0sammo
This is in my 97 civic with turbo d16y7 with p28 ecu
Posted: Fri Oct 26, 2018 9:23 am
attach a datalog showing the issue
Posted: Fri Oct 26, 2018 2:49 pm
by g0sammo
hope ive done this right lol.....
Posted: Fri Oct 26, 2018 3:37 pm
It is reading ok here. IF restarting your laptop does not allow it to be seen properly, then go to the options, settings and make sure that you have the lambda overlay settings such that the conditions are being met.
Posted: Sat Oct 27, 2018 10:00 am
by g0sammo
Thanks Spunkster! I had tried shutting down and turning back on, but apparently thats different than doing a restart on the laptop. That worked for me and everything now displays correctly!
