Car is in recovery mode & cant conect with ECU [Flashpro]
Gaby
Post by Gaby »
So my car was working fine & i decide to program a diferent calibration, so after i programed my Car dont start and cant conect with the ECU of the car. so that means that i cant do nothing about it. id check all fuses and disconect the battery and still in recovery mode. when i conect flashpro with the computer there is a check mark on Driver flashpro OBDII & a X on ecu while is conected to the car.there was a note on my last download saying that
The last Flashpro upload failed.
Failure information : code 0x05 Step 16 Address
0x0FFF00
Explanation: The ECU stopped responding while
reflashing. Check OBDII connector pins
.. PLEASE HELP I DONT NO WHAT TO DO THANKS
Gaby
Re: Car is in recovery mode & cant conect with ECU [Flashpro]
Post by Gaby »
When i connect the FP to the OBDI. it Flash one time every 5 seconds the power and datalog light
With everything plugged in and the key in the on position, go to the Help menu and click on send information to Hondata support. Include a detailed description of the problem.
Gaby
Post by Gaby »
ok i will Thanks
Gaby
Post by Gaby »
So i just got a new ECU but i dont know if i re upload a basmap, the ecu will die again .. what could it be..
Gaby
Post by Gaby »
I dont want to have a $700 hondata and cant use it
Was your FlashPro unlocked from the prior ECU?
Gaby
Post by Gaby »
yes and the honda dealer put a stock tune on the new ecu.. im afraid to program a basemap again and kill the ecu again ..
Gaby
Post by Gaby »
las upload that kill the ecu it show me this
0x0FFF00
(what did it mean )
That does not mean the ECU is dead, it just mans the upload failed and you should be able to re-upload to the ECU and it will be ok.
You must use the Hondata software to return the ECU to stock and then use the unlock function from the online menu to unlock it.
Gaby
Post by Gaby »
well last time it show me that a couldn’t connect with the ECU of the car anymore.. talk with customer services and they told me to send the ecu and FP.. they told me it was the ecu.. so got a new one and im afraid to upload a new calibration
Gaby
Post by Gaby »
hondata already unlock my Fp.. a week ago
Gaby
Post by Gaby »
in runing now 3.1.6.0
when that happend i was on 3.1.1.0
It should be perfectly ok to us the FlashPro with the new ECU then.
