Fuel Change Estimated sometimes will not work
Posted: Wed Oct 03, 2018 10:35 am
by G. Wiffington
For some reason when I do some fine tuning using the Estimated Fuel Change function it will
not work. It does work normally but it likes to pick & choose when it wants to work correctly.
Instead of showing the normal (-1%) or (1%) it will not show any values, instead the
map will just show all whited out boxes.
My wideband is connected through wire D10 & is working 100% correctly. SManager shows the exact
AFR values as the AEM Wideband when the car is running.
If I restart my computer the Estimated Fuel Change function will usually work once my laptop is reconnected to S300.
I am leaning more towards my laptop having some sort of issue. I know a few months ago I was checking my
email on this same laptop & it said my computer has been hacked lol. Hopefully it is just a computer issue.
Re: Fuel Change Estimated sometimes will not work
Posted: Wed Oct 03, 2018 11:43 am
If it works after restarting then it may be a memory issue and restarting clears out the memory.
Posted: Thu Oct 04, 2018 10:02 am
by G. Wiffington
Okay thanks for the input.
