U0301 - ECM/PCM mismatch
Posted: Sat Sep 29, 2018 2:24 pm
by samuelt1995
Hi,
I recently purchase a Flashpro for my civic 2016 turbo.
I flash the computer and then a got a check engine. I looked for the code and I saw U0301 and I'm unable to erase it. I looked on the internet and I see it is a mismatch computer.
I try to flashback to stock ECU and it still showing that error code.
My ECU number is 37820-5AA-C66
I bought my car in Canada
Please help me.
Thank you,
Samuel
Re: U0301 - ECM/PCM mismatch
Posted: Sat Sep 29, 2018 4:52 pm
The error is because the ECU probably has been flashed by the Honda dealer to 2017 to match the TCM.
What calibration did you load? The 2016?
Posted: Sun Sep 30, 2018 4:45 pm
by samuelt1995
Hi,
You are right. Honda had to flash my computer one day because the car rpm varies on the highway.
I first flash with the +6 psi first. Now I back to stock ECU. So you think flashing with 2017 will solve my problem. If so, how can i do it? And if I want to go back to stock ECU, how do I do that?
Thanks,
Posted: Sun Sep 30, 2018 7:23 pm
by samuelt1995
Hondata wrote: Sat Sep 29, 2018 4:52 pm
The error is because the ECU probably has been flashed bby the Honda dealer to 2017 to match the TCM.
I tried to use a 2017 Canada Touring one and it didn't want to flash. I tried many other, same thing.
I flashed on a 2016 one.
How can I flashed with a 2017 one?
Posted: Mon Oct 01, 2018 10:59 am
Can you use the 'support support information to Hondata' function from the help menu (with the FlashPro plugged in)?
Posted: Tue Oct 02, 2018 5:27 am
by samuelt1995
Hello,
I did a firmware update and I was abble to flash on +6 psi 2017. All the error code is gone.
Thank you so much.
Posted: Tue Oct 02, 2018 7:08 am
Ok, glad it is sorted out.
Posted: Thu Jan 21, 2021 6:41 pm
by neodragons
Hondata wrote: Tue Oct 02, 2018 7:08 am
hello, i am also having this same problem. but with the recent update of hondata. its says i cant up load the 2017 or 2018 cvt tune to a 2016. please advise
Posted: Thu Jan 21, 2021 7:09 pm
by neodragons
to add, i was able to do this before on 3.5 i think, but once it updateed to 3.7 it no longer let me upload the 2017 tune
Posted: Thu Jan 21, 2021 9:13 pm
Our crystal ball is broken - please some details.
Posted: Sun Jan 24, 2021 1:21 am
by neodragons
nevermind, went for a drive after uploading the base map and check engine light went away.
Posted: Wed Mar 31, 2021 2:02 pm
by Ermrz99
Hello.
I am not having the same issue. 2016 1.5 T with ECU incompatibility. I tried uploading a 2017 calibration to no avail. I then tried uploading the 2016-2017 and I genuinely did not feel much power. When I was originally running the 2016 calibration I felt the power nicely however the ECU incompatibility is causing emission system problem to show up on my dash. What should I do? I don’t want to have to return it :(
Posted: Wed Mar 31, 2021 3:18 pm
