FlashPro's power LED doesn't turn on
Civic 2016+ 1.5 Turbo
Evildoer
Post by Evildoer »
One question, I just borough a new FlashPro and it's power light never came on. It will flash the ECU by itself or connected to a laptop but the light just won't come on. I know it has power since I can connect it to my phone using bluetooth while the unit is only connected to OBDII, and the mobile app runs. Is there anything I missed or is it a lemon unit?
Vehicle: 2018 Honda Civic Hatch Sport MT
Re: FlashPro's power LED doesn't turn on
It may have been opened and the LED is just bent and not under the hole.
Evildoer
Post by Evildoer »
Now the datalog light flashing lightly when my FlashPro is connected to OBD and also when connected with laptop...Any idea what that is?
This is normal
Evildoer
Post by Evildoer »
Question? Can I open it up and bend the LED back into the hole? Do I need a special tool to remove the LED?
No special tools are needed.
Evildoer
Post by Evildoer »
I can pull the LED out of it socket...Any suggestions?
Jun43
Post by Jun43 »
wait... why are you pulling it out.
just bent it back straight into the hole of the casing
Evildoer
Post by Evildoer »
I can't see any legs of the LED, there is a cover at the base and only the LED stick out and everything else is covered.
Evildoer
Post by Evildoer »
Sorry, I mean I can't pull it out and I cant see any pin
Have you removed the 4 screws and carefully removed the top?
Evildoer
Post by Evildoer »
Yes, can't see the pin of the LEDs, it's covered by a socket. File attached.
Just make sure they are not bent and line up with the holes above them.
Evildoer
Post by Evildoer »
Can't see any pin...Can't even move them actually...So I can't do anything and it still won't turn on...
With the top removed can you see the light coming on?
Does it work normally other than the light if the light does not come on?
