Tables
Civic 2016+ 1.5 Turbo
Awsomsauce
Tables
Post by Awsomsauce »
I currently run the e85 tune in my car. When the car is NOT in sport mode, what should the car be running? The stock tune equivalent? When the car is IN sport mode , should it be running the +6 e85 tune? The reason I ask is that when the car is not in sport mode it still hits the same boost levels as it would In sport mode.
Re: Tables
Without seeing your calibration I do not know exactly how you have it setup.
Awsomsauce
Re: Tables
It’s unchanged, the base +6 ethanol Hondata tune.
Re: Tables
post the calibration you are using please.
Jun43
Re: Tables
Post by Jun43 »
if you using everything unchanged then sport and non sport runs the same boost.
If you want stock boost in non sport mode then you would need to turn on Hondata mode. It will still run off the ethanol mupliter for IGN
Awsomsauce
Re: Tables
Thank you all for the input, system resolved.
