EGR ignition
Posted: Wed Aug 08, 2018 2:05 pm
by Awsomsauce
Can you define what this is. Does EGR stand for exhaust gas recirculating or something else. What do the EGR numbers represent?
Re: EGR ignition
Posted: Wed Aug 08, 2018 2:59 pm
The column index is the percentage of combustion chamber charge that is exhaust gas. It is mainly used at part throttle. At full throttle the knock ignition limit table more or less controls ignition.
Re: EGR ignition
Posted: Fri Aug 10, 2018 10:47 am
by Awsomsauce
So if I were looking to tune the ignition for more advance timing in the ignition, for more power, which ignition table should I be looking at? I know that the ecu uses an algorithm to determine ignition timing according to the Hondata video on tuning the x gen. But it appears there can be some tuning done still.
Re: EGR ignition
Posted: Sat Aug 11, 2018 1:09 pm
Knock ignition limit table.
Re: EGR ignition
Posted: Mon Aug 13, 2018 8:48 am
by Awsomsauce
Thank you 🙏🏼
