JDM DC5 Type R with 3problems
SunnyShao
Post by SunnyShao »
Hi all,
I have got a Integra Dc5 Type R(with stock engine) and recently just bought a PND hondata v4 ecu.
I start by uploading the k20a itr base map from hondata(PRB) and it throws out two codes: P0117 water temp low voltage and P0112 IAT temp low voltage.
The water temp gauge in the car was at high position with engine light on(solid,no blinks)
The car idles higher than usual (at 1300rpm) even the idle speed set at 750rpm in the calibration.
Please advice if there's anything i can do to solve these problems.
Thank you.
Re: JDM DC5 Type R with 3problems
SunnyShao
Post by SunnyShao »
It is KPro4 - 44371.
Yesterday night i keep on trying but with no luck,
Check engine light still on and cannot engage the vtec
SunnyShao
Post by SunnyShao »
The ECU no.is 37820-PND-A06.
It looks like this was sold as an install kit to our dealer Driven, You should contact them to see if they can help you resolve this issue.
Driven Performance
50 Genting Lane #01 - 04
Singapore 349558 Singapore
+65-94875000
KPro installer
On site Reflash
joel@driven.com.sg
www.driven.com.sg
