Setting Anti Lag target to no load effects????? Is it possible to set the target to 0
gtfrede07
Post by gtfrede07 »
Would this just create a adjustable studder?
I want to use this feature because my on the fly launch control adjustability is gone now for my flashpro equipped 2018 si that is still all factory including catalytic converter.
I know to not stay on this because it builds heat regardless but what setting could I put to this that will cause the least amount of damage possible if any????
gtfrede07
Re: Setting Anti Lag target to no load effects????? Is it possible to set the target to 0
Post by gtfrede07 »
ANY INPUT?
This would be very bad. I wouldn't even recommend setting it lower than 100kpa.
gtfrede07
Post by gtfrede07 »
dam...I want my adjustable launch limiter back badly. I used it ALOT during my scca events because the available traction changes on the fly throughout the day. Is there a way to make this happen for me?
Im not enjoying that change at all.... wish I wouldnt have updated now.
Just disable the anti lag in the calibration and you can still use adjustable launch control settings.
https://www.hondata.com/help/flashpro/l ... %2Bcontrol
gtfrede07
Post by gtfrede07 »
It doesn't work anymore on 2 different tunes. Anti lag not selected. No adjustment via cruise switches....
