I'm also trying to get this option working on my supercharged fn2. I read that Hondata has fixed this issue but I cant find the solution.
I have a feeling my 6th gear ratio figure in the settings is incorrect. I have a longer 6th gear kit installed. Checked the stock figure and this is the same as what i've got. 0.738.
My cal is a MAF based calibration
Cruise control
Re: Cruise control
I found the gear ratio for my longer 6th gear and put this into the calibration.
Cruise control is now operating correctly
Re: Cruise control
Why did you change the transmission ratio of your 6th gear?
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Re: Cruise control
A lot of guys who are boosted put a longer gear in for better MPG while cruising in 6th.
