Honda Civic Type R -model 2009
eddiev
Post by eddiev »
HI All,
I am building an Ariel Atom replica and have purchased a KO20Z4 MOTOR from a honda civic type r as sold in south africa.My ecu no is 37820-rsp-n02.
I have a near to complete harness with all the dash parts a i would like to use them.Have the key as well as ignition key assembly.
Want to start the motor after doing the mock up wiring with the motor.
What should i check and make sure is connected so i will be able to start the motor.
Regards
Eddie
Re: Honda Civic Type R -model 2009
You will need to look at a wiring diagram in the factory service manual. A K-Pro will not work with this.
eddiev
Post by eddiev »
Where do i find a service manual so i can get the wiring diagram.
thanks
eddie
You will need to contact a Honda dealership for this.
You will need a special FlashPro form Ariel Motors.
