D16Y8 base timing question
Turbod16chris
When setting the base timing on a D16Y8 with a p28 and s300 this is what I did ... I set the base timing at 16 deg then I selected the entire ignition map and took out 4 deg across the entire map. My question is will this work for my application thanks
Zperformance
Re: D16Y8 base timing question
set base timing at 16. Adjust fuel and slowly add those timing back and see how the car respond.
Turbod16chris
ok thanks for your help
