Exocet/KMiata Swap Install Questions
jwagner
Post by jwagner »
Greetings,
I'm installing a K20A2 into a Miata-based Exocet with a KMiata swap kit. This changes things a bit as it's not a plug-and-play type of swap - I had to do a bunch of manual wiring to get things connected.
-Vehicle: Exomotive Exocet with K20A2, KMiata adapter harness.
- KPro V4 SN 45189, Firmware 11.00, SW 4.3.5.0
- ECU 37820-PND-A56, KManager IDs ECU as "Type PRB - US RSX Type S"
The ECU is installed and communicating with the KManager software. Calibration uploads work, and I can turn the fuel pump on with the "Always On" option. I have not tried to start the car (no fuel yet), although the engine turns over when the key is turned to START.
What I'm having problems with or not understanding:
- Reading sensor screen, IAT and ECT are reading 32 degrees. Stock Honda IAT/ECT sensors.
- Again on sensor page, TPS stuck at 0%. I have traced wiring and the TPS has Vcc/Ground and the sensor varies between .3v and 4.6v depending on throttle position, so that looks right.
- Battery voltage on same screen reads 0V
I am assuming that with the ignition in the ON position (which the ECU recognizes) that these values should read the actual temps, TPS position, and battery voltage, correct?
Arno
Re: Exocet/KMiata Swap Install Questions
Post by Arno »
Are pressing F10 first to start datalogging with the ignition ON and Kmanager declaring the ECU as 'online'?
Only then will the sensor data be updated/'live' in the sensor list and any dash templates.
Bye, Arno.
jwagner
Post by jwagner »
Thank you!! The sensors are being read and with the exception of the IAT reading about 30 degrees F too high, everything looks good.
Now I need to find a tune to get a 12.5 to 1 normally aspirated engine started up.
Jim
jwagner
Post by jwagner »
Swapped the K20 sensor for a '94 IAT and the temp values look much more realistic. Put a couple gallons of E85 in the tank, turned the key, and it runs!
Need to sort out a bunch of stuff, but got past a huge milestone this weekend.
