can you help me with this
how to shoot flames on cat back with hondata flashpro
in all the forums it says. Delays time and adds gasoline. My question is how to do it well.
to which rpm should I put it .. how many degrees to draw and how much gasolna to add
K20z3 stock motor ..header and cat back
K20z3 shoot flames
Re: K20z3 shoot flames
To get exhaust pops/burbles, you have to keep the fuel on and retard timing for a short while after lifting throttle. That's basically what the Jaguar engineers do on their F-Type.
https://www.youtube.com/watch?v=WsUsno-Mv2E
While the ability to leave fuel on for a while after throttle lift is defined, Hondata doesn't allow any modification of timing during overrun conditions so while you can keep the fuel on, the corresponding tables that govern timing during throttle lift aren't defined.
