Injectors being cut
darren
Injectors being cut
Post by darren »
So if I'm driving along at say 30mph, 1% to 2% throttle, my injectors keep being cut causing a jerk.
Engine is a b16 on ITB's
Any ideas?
Re: Injectors being cut
Has this been properly tuned on the dyno?
darren
Post by darren »
It has been tuned on a dyno by myself, its my first tune so I'm still learning but runs great apart from 1-2% throttle opening. I shall upload the datalog
darren
Post by darren »
You can see the problem in the first 15 seconds
Post the calibration as well
darren
Post by darren »
Calibration is now attached
Do you have the MAP sensor connected and reading vacuum?
darren
Post by darren »
Yes, vacuum taken from all 4 runner's to a vac box, then map sensor reading vac from there
IT is most likely form the overrun fuel cutoff settings. Try adjusting those and see if that has the desired effect.
2x0
Post by 2x0 »
Go into TPS parameters, lower the TPS % for overrun fuel cutoff (TPS), and lower the numbers for MAP (kPa) in the overrun cutoff (MAP). I use 18-19 on mine up to around 4000rpm and its smooth as can be.
'91 CRX, B18c1, T3/T4, 17psi on e85, FIC 1000cc's, S300 V3 P28
