B18c ,stock internals ,1000cc injectors,10psi base map
Efreng35
Post by Efreng35 »
how does this look to start. pump gas, 10psi, 1050 injector dynamics, 57trim turbo, any input would be great.
Efreng35
Re: B18c ,stock internals ,1000cc injectors,10psi base map
Post by Efreng35 »
Any experience tuners look at this see what they think?
Zperformance
Post by Zperformance »
Do you have a wideband hook up? What injector are you running becuase you didnt calibrate the deadtime at all. assuming self tuned/basemap? timing a bit all over the place. How does the car drive?
Zperformance
That should be a better and smooth basemap. Let me know how the afr and the car run.
Efreng35
Post by Efreng35 »
Thanks for the response!! It was actually tuned by a shop in San Antonio. Once I saw the map I had to question the tune. I will try this map out. Would it work for e85 as well?
Zperformance
Efreng35 wrote: Mon Jul 02, 2018 7:33 pm Thanks for the response!! It was actually tuned by a shop in San Antonio. Once I saw the map I had to question the tune. I will try this map out. Would it work for e85 as well?
No this will not work on e85. Pm me and i can dial in a map for you.
Efreng35
Post by Efreng35 »
Awesome. Pm’d Thanks for the help!!
