Civic Ep3 (EU) with 3 problems
Posted: Tue May 22, 2018 11:09 pm
Hello
A have a Honda Civic Ep3 2002 (EU) with PRC Ecu, k24/k20 frank, k20a cams, walbro 255 fuel pump.
K-pro serial is 14363.
Version software 4.3.5.
K –pro V3
i run the car in close loop. (i saw my o2 sensors wont work with my prc ecu)
I had this engine with no problems in my civic ej9 96-00. (no errors in hondata)
After I swap the engine and tranny in the EP3 I had the following problems.
1. I have the battery light on.
The wiring was check by a electrician and its ok, the alternator is ok, the battery is new.
Battery voltage stays between 13.8-14.2 when the engine is running.
2.I have the P0452 eror- Fuel Tank Pressure sensor low voltage when I star the car. If I delete the error it wont appear again that day.
Does my car has this sensor? I saw in other link that I can disable it? how?
3.After I drive the car about 50-60 min, i gradually lose power.
the more I go, the more I lose power, hardly gain 6k-7k rpm
please help
thanks
K –pro V3
please help
thanks
