h22a4 2000cc injectors wont idle unless on the throttle
BoostedCB9
Post by BoostedCB9 »
hey guys fully built h22a4 in my 93 accord wagon trying to get it up and running for break in. only thing stock is the cams. Currently on fuel injector development 2000cc injectors, getting ready to turbo it just wanting it up and running for I install the turbo. Also does anyone possibly have a wiring diagram for the map sensor k to h. currently running based off the tps.
H22 turbo wagon.s3d
G. Wiffington
Re: h22a4 2000cc injectors wont idle unless on the throttle
Post by G. Wiffington »
Did you ever get it to fun without being on the throttle?
What map is this? Is it an H22 basemap from the given calibrations from Hondata? If so it seems that those H22 maps are way too rich.
What is your AFR at?
BoostedCB9
G. Wiffington wrote: Tue May 08, 2018 10:26 am Did you ever get it to fun without being on the throttle?
I was not decided I’m just gonna finish installing my turbo kit and take it to my tuner, the stock calibrations do run really rich
G. Wiffington
Good Luck !
Zperformance
Post by Zperformance »
BoostedCB9 wrote: Thu May 03, 2018 4:48 pm hey guys fully built h22a4 in my 93 accord wagon trying to get it up and running for break in. only thing stock is the cams. Currently on fuel injector development 2000cc injectors, getting ready to turbo it just wanting it up and running for I install the turbo. Also does anyone possibly have a wiring diagram for the map sensor k to h. currently running based off the tps.H22 turbo wagon.s3d
so many wrong things are going on at the same time. Seem like you are having a charging problem 12v with the car on. Low ignition(set your dizzy timing) and map sensor is stuck reading 10psi.
