K-Pro in a non-honda vehicle
Posted: Tue Apr 24, 2018 12:43 am
Putting a K24 into a non-Honda and considering a K Pro to run it.
Looking to clarify which ECU/wiring harness/engine combination will work.
There's a lot of information online that is difficult to piece together, will the below setup work:
02-04 CRV manual transmission ECU/wiring/engine with an "immobilizer bypass" should work with/without K-Pro when transplanted, correct?
Can any 02-04 CRV ECU be converted to K-Pro or is it only some of them?
Will this ECU operate the important dummy lights (ie. oil pressure and coolant temperature)?
What kind of tach output will the Honda ECU output?
Will the K-Pro in a CRV ECU be able to operate the 200hp "full vtec" engine (the 02-06 or so TSX) if I swap to it?
Will the K-Pro operate normally if VTC is mechanically disabled? (ie intake cam timing fixed and VTC solenoid removed) Will it go into some sort of "safe mode" or "limp mode" or similar?
