Hey guys I need a base map for Hondata S300v3:
My email address is tien3585@yahoo.com
-GSR 81mm block
-9.0:1 CP pistons and rings
-LS H-beam eagle rods ARP rod bolts w/ ACL bearings
-LS crank
-GSR tranny
-GSR Head
-CTR cams with super tech dual valve springs and keepers
-Adjustable BWKRS cam gears
-RC 1000cc
-Omni bar map sensor
-Garrett turbo (715583-5006) 70 AR housing/ 63 exhaust side
-2.5in exhaust down pipe to 2.75in indivia exhaust system
-38mm turbonectics wastegate w/ blue spring (5-7psi)
Let me know if you need more information. This is my first on getting base map from online through email so can someone tell me how to load it to my hondata S300???
Base map for Turbo LS VTEC in a GSR block.
Re: Base map for Turbo LS VTEC in a GSR block.
Anyone??? I might have to get pherable basemap I heard the was good.
I use phearable all the time and never have had any issues. Just adjust fuel pressure to get afrs right and keep an eye on them and itll run perfect.
