What fuel compensation table effects cold starts?
Posted: Fri Apr 20, 2018 2:57 pm
So I usually am able to figure out my issues from looking on the forum here but, I was somewhat confused about which fuel compensation table directly effects the fuel during a cold start or during the cranking period when starting?
I do not have my calibration or datalog to share because I am at work right now.
1993 Honda Accord
Euro-R H22A
s300
The issue I was having was that I have been tuning my car in temperatures from 40 degrees Fahrenheit to about 65 degrees but, last weekend the weather in Maryland, USA was about 80-85 degrees outside which caused my car to give way too much fuel during cranking & it would not start. This is the first time I have started my car during warmer weather & the first time tuning during warmer weather since I got my s330 installed during Winter time. Also, this is the first time I have not been able to start my car on first try, which is why I was concerned. I have heard tuning in different air temperatures can cause some issues but I thought it was weird I was unable to start my car.
I have never had any trouble starting my car during the colder months but as soon as it got really hot outside my car was giving way too much fuel during cranking.
I tried subtracting fuel in the "Cranking Fuel Trim" in the Fuel Trim Parameters & eventually got it to start. But, I had to give some throttle for a second or two to get the car to idle.
Which table under Fuel Compensation effects the cranking fuel compensation?
I read in another thread that the "Water temperature fuel compensation cranking" is what controls the compensation for cranking. Is this the table that needs to be adjusted according to the temp?
I would have thought it would be the Intake Air Temperature that effects the cranking fuel compensation due to the temperature of the air. Is the water temperature where the cranking compensation is effected?
Sorry I just wanted to understand since the s300 Programmable ECU Guide does not have too much description about this.
1993 Honda Accord
Euro-R H22A
s300
