02 rsx type s
Serial: 37820-PRB-AO4
Ecu#: 2068-300749 OG17
Im having a weird problem, and im thinking it's a ecu problem. Car has been dyno tuned and running fine for about a year. I recently had some leaky injector o rings, and decided to change them out. When i was finished, i turned on the key to check for leaks, all was fine. My mistake was that i forgot to put back the ground wire on the valve cover, so the wire was just dangling on the v. Cover. The engine started fine, when i saw it i shut it off rite away and secured the wire to the v. Cover. The problem is the car fires up but idles real ruff, and the air/fuel is all over the place. Also when i connect the laptop to the kpro and turn the key in the ( II ) position, the data/recording tabs highlight, but the upload tab does not highlight at all. Already tried new usb cable, double checked all the grounds. Im thinking when the ground was loose it might have damaged the ecu. Any help would b appreciated.
Upload tab!!!
Re: Upload tab!!!
You must have a calibration loaded in order to see the upload button. What you are describing should not have damaged anything.
