Continental Ethanol sensor problem
Posted: Tue Apr 03, 2018 7:07 am
I bought and installed this sensor: https://www.ebay.co.uk/itm/122012682233 ... 2012682233
But it gives me readings (out pin) around 5v even inside tank is regular pump fuel.
Even when I disconnect power and ground, that wire which goes to ECU (ECT2 pin) gives ~4.2V, and in flashpro manager value is changing from 50 to 100% fast.
Double checked this pin on ecu.
Second ECT sensor enabled - UNCHECKED
Ethanol input set to ECT2
Where is the problem?
