need a unique h22 basemap
Slipknotko
Post by Slipknotko »
so I have tried all the h22 basemaps on the forums the car starts then dies right away.
id 1000cc injectors
stock map sensor for now
wastegates set to 8 psi springs.
i just installed a rywire tucked harness with conversion built in for the new obd1 hondata ecu brand new from rywire.
tach and fuel pump i wired in as well as the wideband o2 sensor is wired into d14.
i live in alberta which i think is 14psi atmospheric pressure.
i also am not running an iac valve and have the throttle body opened a little to allow air in it ran on the link ecu prior to the wireing harness and ecu change . i just need it to run so i can get it to the dyno shop.
fuel pump is cycling fine.
i get an error o2 heater and iac i disabled iac and o2 no change .
i hope you guys can help
Slipknotko
Re: need a unique h22 basemap
so I was able to keep it running to do some datalogging . still runs like garbage hope this will let you guys help cause my car is stuck in my underground parking garage till I get it running well enough to the dyno shop 40km away
G. Wiffington
Post by G. Wiffington »
I have a decent H22 Map for a Euro-R setup (11:1 CR)
What is you AFR upon starting? I would bet it is way too rich, as all the H22 maps seem to be. Pull some fuel from the whole map & see if it helps out.
r1z1nginfern0
Post by r1z1nginfern0 »
G. Wiffington, I have been struggling to get my euro r to idle and not cut after throttle input then letting off. If you have a stock map could I possibly get it? I would greatly appreciate it seeing how the tuner I'm trying to get to is 300 miles away...
99 GSR
01 Euro R H22A (stock PDE IM, injectors, and internals)
2 wire iacv
Egr delete
1320 H2B Header
InterAV
Post by InterAV »
r1z1nginfern0 wrote: Sun Aug 11, 2019 8:53 pm G. Wiffington, I have been struggling to get my euro r to idle and not cut after throttle input then letting off. If you have a stock map could I possibly get it? I would greatly appreciate it seeing how the tuner I'm trying to get to is 300 miles away...
99 GSR
2 wire iacv
Egr delete
1320 H2B Header
Did you ever manage to find a good basemap? I have pretty much the same setup as you.
G. Wiffington
Crap my bad guys, I totally forgot to follow up on this.
I have a good map for you guys if you still need it.
I am at work but I will write myself a reminder to upload it tonight.
Sorry guys!!
G. Wiffington
Hey guys if you want to, I have my map from last month uploaded onto another
post that I made if you want to download that one..it works really great
for my setup.
The title to the post is: "RPMs & Duty Cycle Lines on Graph Wavy in VTEC"
I uploaded a pull & my map is there as well!!
trippySTICKS710
Post by trippySTICKS710 »
G. Wiffington wrote: Tue May 08, 2018 10:29 am I have a decent H22 Map for a Euro-R setup (11:1 CR)
you still have the euro r basemap? i really need one...
G. Wiffington
Sorry wayyy late.
Yes, still need it?
