Weird fuel variation from ELD voltage
Posted: Mon Mar 05, 2018 4:11 pm
Hello guys,
I don't think I've ever had this issue with S300 before, nor that I noticed
Fuel injection time is changing when ELD voltage is changing
At first I wasn't sure if that was the issue but following a thorough step by step of what it could be, I am now sure that it is the issue and potentially a bug somewhere because as far as I'm aware, the ELD should not affect the fuelling
It's a basic setup, 1000cc ID, 4bar map sensor, turbo charged B18C
I started mapping the car and when I opened the window to put the dyno commander through, the engine tone changed and after further inspection, the car was going lean as I press the windows open switch
I knew my deadtime correction were correct but I still double check
Fuel pressure not moving
Battery voltage not moving (Above 14 at all time)
Voltage at injector not moving (Above 14 at all time)
Battery reading on issue not moving (Above 14 at all time)
ELD enabled, disabled in the S300 was making no difference
Deadtime set to 1ms at all voltage did not make any difference
The only thing that was moving was the ELD voltage and at the same time the injector opening time
I ended up disconnecting the ELD input to the ECU and it immediately fixed the problem which also seems to have increase the base deadtime somewhere in the background to the overall map
Any idea what it could be?
You can see on log attached the ELD moving as well as injector duration between 25 and 40s of the log
This is by simply turning the interior heater on and off
