dual flash
dual flash
Is there a way you can make a dual flash like +6/+9 or +6 /+6e85 or +9/+6 e85 with the stock and sport mode. thank you
2020 civic si,flash pro,afe intake,afe exhaust,prl intercooler,acuity short shift and eibach springs
Lilwonton17
Re: dual flash
Curious to still know as well
Re: dual flash
The only way to do it is adjust the TQ tables
IF you put 250nM, I believe that's around 20psi
Lilwonton17
Re: dual flash
Nope torque tuning is to adjust the torque nothing to do with boost. Boost is the TC Maximum Pressure Ratio. But don't think a dual tune is possible as of right now.
Re: dual flash
Lilwonton17 wrote: Wed Jun 13, 2018 1:34 pm Nope torque tuning is to adjust the torque nothing to do with boost. Boost is the TC Maximum Pressure Ratio. But don't think a dual tune is possible as of right now.
You do know that the TQ is controlled by boost/TPlate.
To limit the TQ, it has to lower the boost command/TPlate
Lilwonton17
Re: dual flash
oh idk lol I have a personal tuner to do that for me. But on my SI both normal and sport are already set at 650nm to need to lower it.
Awsomsauce
Re: dual flash
So I did do as suggested above with the torque settings and it does work. It takes some driving before the ecu learns the trims but when you check the box to have the torque separate you can tell. In my car it still hit the high boost but the torque was lower.
