Install Flex Fuel - Sensor Reading High?
Posted: Sun Feb 25, 2018 3:14 pm
by integraguy041
Hi, Hoping someone can help me out.
2018 Civic, and just installed a Zeitronix ECA-2 Ethanol content with their Flex-Fuel Sensor.
Got it all hooked up and flashed the 9psi Flex Fuel map.
Ethanol is reading 21%, and I am running on straight 93 Octane (Live in IL if that makes any difference).
If i disconnect the output wire on the Zeitronix that goes to the ECT2 plug, the reading on Hondata goes from 21% to 100%.
I was thinking maybe i put the output wire on the ECT2 plug on the wrong pin, but if its reading that cant be the case right?
I attached my tune and datalog.
Hopefully this is an easy fix/dumb mistake.
Thank you,
Kyle
Re: Install Flex Fuel - Sensor Reading High?
Posted: Sun Feb 25, 2018 3:59 pm
by Jun43
"Ethanol percentage defines the range of the signal from the ethanol control unit. Most units use a 0 to 5 volt range where 0 volts is 0 percent ethanol and 5 volts is 100 percent ethanol
The ECU ECT2 input has a pull up resistor to 5V internally, and some ethanol content devices cannot pull the output voltage down to give an accurate reading at low ethanol content percentages. We recommend these settings:
Zeitronix ECA : 0.34 volts = 0%, 4.97 volts = 100% (will not read below 15% ethanol).
Innovate ECF-1, MTX-D, ECB-1 : 0.00 volts = 0%, 5.00 volts = 100% (will not read below 1.5% ethanol).
In the USA pump gas has 0 to 10% ethanol (typically 10%) and E85 fuel is 55-80%, depending on location and time of year."
Posted: Sun Feb 25, 2018 4:07 pm
Yes, that. Well said.
Posted: Sun Feb 25, 2018 4:11 pm
by integraguy041
Jun43
Thank you for the info.
I will change the voltage settings and see how that works.
So based on your reply, i really should have got the Innovative one correct?
Seems like a more accurate sensor, since it can read 1.5% - 100%?
Posted: Sun Feb 25, 2018 4:12 pm
by integraguy041
Hondata wrote: Sun Feb 25, 2018 4:07 pm Yes, that. Well said.
@Hondata, thank you for the confirmation.
Posted: Sun Feb 25, 2018 4:28 pm
by Jun43
integraguy041 wrote: Sun Feb 25, 2018 4:11 pm Jun43
I ran ECA with no problem. its pretty accurate with the voltage adjustment. you just treat e15 on the table as straight pump gas.
