Got my CARB Flashpro and a couple questions
Posted: Sat Feb 24, 2018 9:35 am
by gtman
When I go to New Calibration and make a couple changes (like enabling Hondata mode) it never asks if I want to save the tune. When I upload it, how do I know it's the calibration with the changes I made?
Also, I know there isn't much to change on the CARB but I can play with boost and torque. Is there a tutorial online anywhere to help me figure out what I need to change/adjust in those different tables?
Re: Got my CARB Flashpro and a couple questions
Posted: Sat Feb 24, 2018 2:35 pm
To save it you must go to the File menu and click on save as and give it a name and save it. If you have a calibration open and upload to the ECU that is the calibration that will be on the ECU.
Posted: Mon Feb 26, 2018 5:33 pm
by gtman
So does anyone have any guidelines or help for adjusting boost on the base maps?
Posted: Tue Feb 27, 2018 10:44 am
To raise boost you must adjust the TC Maximum Pressure Ratio table:
https://www.hondata.com/help/flashpro/t ... ub=maximum
This is in BAR.
Posted: Wed Feb 28, 2018 7:26 am
by gtman
What about TQ and these other tables?
Posted: Wed Feb 28, 2018 11:43 am
Those should already be set to levels of 3 BAR which should allow any modifications you make to the TC MAX pressure ration table.
Posted: Thu Mar 01, 2018 12:14 pm
by gtman
I'll tell you what's confusing. You say to just adjust the TC max pressure only. A guy on CivicX who is one of their Flashpro gurus told me to bump up the torque table past 4000RPM as well. I'm trying to adjust the +6 tune to up the boost a bit on the high end but protect the CVT a little down low.
