Flashpro won't connect via Bluetooth
Icemanrocks5
Post by Icemanrocks5 »
I have samsung Galaxy s8 plus and it would connect via bluetooth before and now it doesn't do it anymore. I've tried to reset my phone, unplug flashpro and plug it back in, and nothing seems to work for it. Also my phone did update recently. Any suggestions?
Re: Flashpro won't connect via Bluetooth
Plug the FlashPro in to a laptop , open the FlashPro Manager software and go to the FlashPro button at the top then click the Bluetooth tab and change the pin number to something you will remember, then try to pair with your phone in the android settings. After it pairs, then open the Hondata app and it should allow you to connect.
Jclrk279
Post by Jclrk279 »
I did this but it says connection failed.
Does it fail to pair in the Samsung Bluetooth settings or the Hondata App?
Jclrk279
Post by Jclrk279 »
Hondata app, I've tried to use the app alone on the Samsung Note 8 and it says connection failed. Then I tried connecting through the app on the head unit and it also says connection failed. I have the most current version of the app and I downloaded the most recent Flashpro manager. I also checked the 2018 civic head unit box.
You must uncheck the alternate pairing mode if you want to connect to your phone. After making this change you will have to unplug the FlashPro completely form the USB and the vehicle to restart it.
Jclrk279
Post by Jclrk279 »
Ok I did that and it still says connection failed. So I tried starting fresh. I unpaired my flashpro from the computer and tried to reconnect through bluetooth and it wouldn't pair. I unplugged the USB and then reconnected. Tried pairing to the flashpro again and it paired. opened the hondata app on the phone and its now connected! So I just tried connecting to the FP with bluetooth on the headunit and it kept saying couldn't connect. I changed the bluetooth password to 0000 and re-checked the 2016+ civic box, then unplugged the ECU and USB. Tried connecting headunit bluetooth to FP and it failed. I then reconnected the USB and ECU and it connected to the headunit bluetooth. I then tried to connect to the headunit app to the FP and it said connection failed. I unplugged the USB and left the ECU plugged in and it connected! running great on V1.5! Do I have to leave the FP plugged into something for the headunit to read the FP?
You can only connect via the phone with the setting for the 2018+ civic disabled.
Jclrk279
Post by Jclrk279 »
cool! Thanks for your help!
tomh1979
Post by tomh1979 »
I found hitting the lightning bolt repeatedly eventually works from within the android app, not sure why i have to do that, but worked on both My Pixelbook, and Pixel 3xl.
guilt79
Post by guilt79 »
Hi everyone.
I got the same issue of unable to pair my FP with my headunit. I tried disconnect, reconnect, uncheck the setting for 2018+ and still cannot connect.
I suspect my FP is link to my previous headunit. Now I’ve downloaded the latest apps from play store, it can’t even detect my FP.
Anyway I can reset the my FP so that it won’t link to old headunit?
Thanks.
You must use the Dash App: https://www.hondata.com/software
You must also pair the FlashPro from within the Bluetooth settings of the head unit before trying to use the app.
kpthemanatee
Post by kpthemanatee »
I have a 2019 honda accord sport 2.0 manual.
I bought the hondata mobile app and I have the flash pro plugged into the obd2 port.
The app connects to the flash pro but only for like 5 seconds and then no longer shows data. I restart the app and it just continues to do this.
I have tried using Bluetooth 4.0, 3.0 and the second method.
Help!
Are you using an IOS, or Android phone?
kpthemanatee
Android. Note 20 ultra
