add additional column in Smanager for map
Place your display templates here with a screen shot of it for previewing.
frederic1973
Post by frederic1973 »
need suport
did someone can confirm how to process to manage aditional column in smanager ?
fred
Re: add additional column in Smanager for map
If you go to the Options menu you will see the show 3 bar, 4 bar and 5 bar tables listed. This is where you can see additional columns. You can then edit those columns by right clicking them.
frederic1973
hi,
my aims is to add column in table for low speed ignition, high speed ignition, low speed fuel, high speed fuel.
in my case, i'd like for example manage a new column and value for 2350 rpm to insert
frederic1973
hi,
You cannot add columns. You can only change the indexing by right clicking.
frederic1973
thanks for your reply.
possible to insert index in table and change value :)
it's perfect
