ISO Basemap
projectFD2
ISO Basemap
Post by projectFD2 »
Whats going on guys?
I have an 07 Civic SI Sedan. Swapped to a complete 2008 k24a2 long block.
Installed parts list:
Type R oil pump with new tensioner, chain, and guides. Drag Cartel lower chain guide.
I have a non ported RBC Manifold, I did port match the throttle body to my Hybrid Racing ZDX throttle body spacer.
Zdx throttle body installed.
stock k20z3 injectors
Skunk 2 Racing cold air intake.
Skunk 2 Racing Megapower Header.
Skunk 2 Megapower RR exhaust.
Exedy light weight flywheel.
K20z3 transmission with stage 1 exedy clutch kit.
I have flashpro and am just looking for a proper base map for the time being that wont damage my engine while i wait for my tune. Im new to using flashpro so help would mean alot.
Thanks in advance.
typer86
Re: ISO Basemap
Post by typer86 »
I can create a base map for you.
But listen - you have an individual Setup so few drive cycles are necessary for sure.
If you're interested /PM me to discuss necessary details to start the process.
sn0rlacks
Re: ISO Basemap
Post by sn0rlacks »
typer86 wrote: Mon Feb 05, 2018 6:17 am I can create a base map for you.
I’m in need of a k25a2 stock base map for my 07 civic si swap any way you can help
