ECU repair?
Posted: Mon Jan 15, 2018 6:32 pm
Vehicle: non Honda chassis
ECU: prb kpro v4
Issue:
Engine and everything ran fine, or at least started and idled. I redid the engine harness and verified engine would start, it did, but had a wiring issue which thru a CEL, while verifying issue, accidentally connected the BRN/YEL wires to the YEL/BLK wires in the C104 connector... Yep, idiot move.
Tried to start, engine would crank, spark, smell fuel, but won't run.
Replaced the CMP, TDC, and CKP sensors, retried starting. Same.
No CELs, Kpro connects to ECU, able to upload / download maps. Just not able to get engine to run.
I'm thinking I fried something in the ECU, so was wondering if Hondata can check the ECU and repair as necessary?
ECU: prb kpro v4
Issue:
