KproV4 MAP question
Dublocivic
KproV4 MAP question
Post by Dublocivic »
Hello all,
I am in the process of putting together a K24/eg build and had a question about KproV4 in regards to the Map sensor. The current build will be in a normally aspirated form for a few HPDE shakedown sessions. After things are sorted out with the chassis, I will be installing a Rotrex setup for some timed events. My question is: Can I run a 4 bar map while in an NA format? Or would I need a factory type Map sensor? Trying to get by without buying needless sensors. Thanks!
Re: KproV4 MAP question
Yes you can use a 4bar for both boosted or NA applications.
Dublocivic
Perfect. Thanks!
