02 ecu and 05 harness
Posted: Thu Nov 30, 2017 9:30 am
by Miguelmgm
I have'd a mistake and I'd connect 05 harness with 02 ecu with k pro now is red light all time and don't have communication with the laptop
Re: 02 ecu and 05 harness
Posted: Thu Nov 30, 2017 11:17 am
What is the serial number that is on the K-Pro board inside the ECU.
What vehicle is this currently being used in?
Posted: Thu Nov 30, 2017 3:24 pm
by Miguelmgm
Spunkster wrote: Thu Nov 30, 2017 11:17 am
05003239 is te only one in the K-Pro it was for a swap and the harness is Acura 06
Posted: Thu Nov 30, 2017 3:25 pm
What is the part number on the outside of the ECU?
What vehicle is this being used in?
Posted: Thu Nov 30, 2017 4:22 pm
by Miguelmgm
Spunkster wrote: Thu Nov 30, 2017 3:25 pm
PRBA02 in Honda EG
Posted: Thu Nov 30, 2017 4:25 pm
We don't recommend using the 05 harness with engine swaps, but in an RSX if an 02-04 ECU is lugged into an 05-06 vehicle it will not damage the ECU in any way. What vehicle has the ECU been tested in after this was plugged in incorrectly?
Posted: Fri Dec 01, 2017 5:49 am
by Miguelmgm
Spunkster wrote: Thu Nov 30, 2017 4:25 pm
Only in that one then the red light turn on and we don't have communication with the laptop
Posted: Fri Dec 01, 2017 10:43 am
You should try the ECU in a known working vehicle that has the correct harness.
Posted: Fri Dec 01, 2017 5:33 pm
by Miguelmgm
Spunkster wrote: Fri Dec 01, 2017 10:43 am
Yes I tried in Acura RSX have kpro too and I change but de red light stay, whats the mining of red light but is not flashing
Posted: Mon Dec 04, 2017 10:27 am
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
