Boosed cuts at 4400 rpm GSR turbo
RofromNorCal
Post by RofromNorCal »
Im Running S300 V3 with Boost Control Installed
Hondata Map Sensor and COP Kit with Factory K20A3 Coils
on GSR with Vtec pinned
My issue is My Rev. Limit and boost cut come on at or before 3psi
ive have went over all my parameters setting Like Boosted cut and rev. limit
ive amp up the fuel map think it might be it but no change
here is my last Datalog and Calibration
the boosed cut is notice at 0 to 1sec mark
thank you for your time
my guess is it might have to due to Secondary Table coming on but i Change min temp to 298F so i could run
one table due to i do not have a low and high cam switch cause the vtec is pin.
Re: Boosed cuts at 4400 rpm GSR turbo
I don't see any boost cuts, just a rev limit and that could be due to an ignition error that does not trigger an error code.
RofromNorCal
Last night i had cut a 3psi around
but seem like i erase it by mistake
No error codes at thos time
Danielr96
Post by Danielr96 »
Hi RofromNorCal,
It appears that you have a hot boost cut set to -14.7 psi. You might want to remove the negative symbol, upload your calibration and test again to see if you still have the same issue.
