S300 v3 Limp Mode
Posted: Mon Oct 23, 2017 6:59 am
by qwertynull
Hello. I have troubles with my hondata installed on P28 ECU.
When I started the car, it immediately went into Limp Mode and displayed the CEL.
I can not read error codes when hondata is still running in limp mode.
According to my observations it seems to be due to the temperature
Previously, it all began at -20 degrees. Now at +5 Celsius.
Then when I drive a car for some time, the check is turned off and everything is good. The colder the more I need to drive so that the CEL turns off.
(about 30 minutes at 0 degrees Celsius)
I replaced all the capacitors, it did not help.
I tried to update the firmware several times, this also did not help.
Please, help me.
- serial: 30169
- version of software: 2.6.5.0
- jdm accord euro-r/h22a stock engine
20.11.2016.skl
Re: S300 v3 Limp Mode
Posted: Mon Oct 23, 2017 1:46 pm
It sounds like there may be a cold solder joint on the ECU socketing. Can you post pictures of all the solder joints on the bottom of the ECU?
Posted: Mon Oct 23, 2017 8:56 pm
by qwertynull
Posted: Tue Oct 24, 2017 9:19 am
It looks like some of those may not be good solder joints. You should try reflowing all of them.
Posted: Tue Oct 24, 2017 7:33 pm
by qwertynull
Ok, thanks, I will try
Posted: Mon Nov 13, 2017 10:14 pm
by qwertynull
Hi, I soldered all the connections, it did not help. I also checked the presence of a signal in the wiring from the temperature sensor - all ok. Are there any other ideas?
Posted: Tue Nov 14, 2017 10:35 am
Try the s300 in a known working ECU that already has an s300.
Posted: Tue Nov 14, 2017 9:12 pm
by qwertynull
Ok, JDM ecu is suitable to this hondata or I need to use only USDM ecu?
Posted: Wed Nov 15, 2017 10:35 am
It would have to be a USDM ECU.
