Newbie Question
Posted: Tue Oct 17, 2017 3:20 pm
Hello
Can you guys take a look at my datalog?
Short term fuel trim gets super high when idling.
Also my car sounds like a subaru. No cel.
I'm using SManager's built-in base map b16 supercharged 440cc 12ohm.
However I'm using RC 16ohm 440cc injectors.
I adjusted injector dead time accordingly (http://injector-rehab.com/shop/lag.html)
Also I downloaded b16 supercharged 440cc base map at (https://www.hondata.com/forum/viewtopic.php?f=20&t=4396)
Fuel table is different compared to built-in map.
This map have higher fuel table setting and injector size set at 550cc but file name say the map is for 440cc.
Should I use the map downloaded here or just use built-in map until I get to tuner?
My car get tuned in 2 days.
