What system should i get for Prelude????????
H22_Speedracer
Post by H22_Speedracer »
I'm going to do the OBD-2 to OBD-1 swap in my 97 5 speed prelude. What system should i get?? And since Hondata does not sell to the public does the dealer still have a actual Hondata system or are they thier own? (i.e. prospeed calls thier ECU upgrades, prospeed chip not hondata)
97 Base Prelude
Hs Short Ram Intake
Dc 4-2-1 Header
Focuz Race Cat
Greddy Sp Cat Back
whoojong
Post by whoojong »
you can get either depending on the options you want. probably s100 will suite your needs fine. Using a P72 for h22 is the best.
Whoojong
99SSLude
Possible 2 ECU setup in 5th gen Auto Lude?
Post by 99SSLude »
I am planning on running a small turbo setup in my car (99 SportShift Lude) and am of slightly limited funds however I have come to see that to really get the most out of this engine I will be best off using a hondata setup however I can not afford to add turbo and convert this car to a 5spd, but I can't see it being impossible to run both ECU's at the same time after all the TCM half is only really READING from sensors right? so why wouldn't I be able to use a P72 (Which I may have available shortly) to control the motor etc and leave the current ECU intact to run the transmission, I will probably NOT be allowing it to shift on it's own anyways so if that feature ends up going away this is not a problem. What I am not interested in is a burrage of people telling me I am stupid for turbo'ing a auto lude.... Thanks in advance for any assist on this one.
P.S. wiring and electrical things are not a problem for me as I have a background in electronics
