Page 1 of 2
Error code 15 Ignition output
Posted: Fri Oct 06, 2017 3:45 pm
by 300whpcrx
I have a b18c1 in a CRX that has been throwing code 15 since the rebuild. So far I have swapped out the distributor and had the ECU tested. The car will start up perfect and idle fine but once you begin to drive it at anything other than a very cautious pace It will turn off completely and throw the code 15. The car has a chase bays harness and we have double checked the wiring at the distributor to the ecu. Our next step will to be making a jumper harness from the distributor to the ecu circumventing the harness altogether. An help/ tips / info would be greatly appreciated. Thanks !!
Re: Error code 15 Ignition output
Posted: Fri Oct 06, 2017 4:04 pm
Try the ECU in a known working vehicle. If the problem goes away you will know that it is the wiring in the vehicle causing the issue.
Posted: Fri Oct 06, 2017 11:23 pm
by crluver123
code 15 is usually a bad ignition switch
Posted: Sat Oct 07, 2017 3:29 pm
by 300whpcrx
does anyone have a p72 ecu they want to let me borrow?
Posted: Sat Oct 07, 2017 6:50 pm
by crluver123
I'll say it again. code 15 is almost always the ignition switch. the 1% of the time it isn't the ignition switch, it's usually a bad ground.
I have NEVER seen a code 15 be ecu related.
Posted: Sun Oct 08, 2017 3:17 pm
by 300whpcrx
Wouldn't the dash lights and the entire car turn off if the ignition just shut off? the engine will just die if revved any where other than a babied throttle. Not trying to argue i'm open to any solution at this point. Thanks for all your help so far guys!
Posted: Sun Oct 08, 2017 10:25 pm
by crluver123
you would think thats the case but it usually isn't.
I rarely recommend throwing parts at a car without full diagnostics, but this is a rare exception. I suggest just getting a new ignition switch. 99% chance it will fix it
Posted: Mon Oct 09, 2017 6:08 am
by 300whpcrx
I called autozone and ill have a new one installed this afternoon. Ill report back later with an update.
Posted: Mon Oct 09, 2017 3:48 pm
by 300whpcrx
I took the car around the block and the same thing happened. You can drive it and it idles just fine but as soon as you tip on the accelerator while driving it just dies. Thanks for the help so far its killing me not being able to drive it.
Posted: Mon Oct 09, 2017 4:49 pm
What is the part number of the ECU you are using?
Posted: Mon Oct 09, 2017 5:16 pm
by 300whpcrx
Its a p28 with hondata s300. I can pull the ecu and check the actual number if that is more helpful. I had pure tuning bench test it and he said it was ok. I was thinking of emailing hondata and having them inspect it.
Posted: Tue Oct 10, 2017 2:46 pm
by 300whpcrx
Spunkster wrote: Mon Oct 09, 2017 4:49 pm
do you need to know the exact part number?
Posted: Tue Oct 10, 2017 2:51 pm
Yes I need the exact part number that is on the side of the ECU.
Posted: Tue Oct 10, 2017 4:04 pm
by 300whpcrx
Spunkster wrote: Tue Oct 10, 2017 2:51 pm
I pulled the ECU from the vehicle there is no sticker like i hoped with a part number.
The only numbers on the ecu are written in either paint marker (p0151)
on the circuit board 02d011f0-1500 a8y-e
I painted the cover when I was a young ricer boy and may have taken off the part number.
The ecu was just recently sent to hondata for an upgrade if that helps at all.
Posted: Tue Oct 10, 2017 4:11 pm
look at the sticker that should be on the gray plug that can be seen with the lid off.
