Page 1 of 3
TC with other management system
Posted: Mon Oct 02, 2017 7:47 am
by BEKA-BEKA
I have additional maps for fuel and ignition table with O2 voltage as the load index with the engine management I have. Can I use an O2 sensor 0-5voltage input from this ECU with Hondata Traction Control 0-5v output?
Re: TC with other management system
Posted: Mon Oct 02, 2017 11:23 am
That is a question you need to ask the other management system. The TC can provide a 0-5V signal for slip.
Posted: Sat Nov 18, 2017 10:37 am
by BEKA-BEKA
For Honda Civic 2006+, Do we use the Active Wheel Speed Sensor Wiring method, where we cut -'ve wire, strip and join to the Traction Control module input?
Posted: Sat Nov 18, 2017 9:17 pm
Yes, the 06 Civic has active sensors.
Posted: Tue Nov 28, 2017 4:31 am
by BEKA-BEKA
Hence, We only need to cut 4 wires on the ABS controller harness, i.e. FL-GND, FR-GND, RL-GND and RR-GND, right? And connect the FL-GND that has been cut to FL- and FL+ of the Hondata TC wiring with no polarity? And do the same with the other three cut cables, right?
Posted: Tue Nov 28, 2017 7:21 am
Yes, see
Posted: Tue Nov 28, 2017 8:48 am
by BEKA-BEKA
I was using the connector wiring on the reference on the help file, where it uses all the + and - of the wheel sensor wiring. I've cut a couple of + cables till I realized only the -GND cables would be used.
BTW, Can we use the IGN1+ on the ABS Controller harness for the power?
Posted: Tue Nov 28, 2017 11:08 am
It is best to use the power and grounds at the ECU to avoid ground loops and voltage offsets.
Posted: Thu Nov 30, 2017 8:16 pm
by BEKA-BEKA
With the 0-5v analog output from the Hondata TC orange wire, How can we relate this to the Slip (%)?
Does this mean increase in the analog voltage output also mean increase on the Slip (%)?
Posted: Fri Dec 01, 2017 8:56 am
You can configure the output voltage in the software. The output voltage is proportional to over slip (not slip).
Posted: Sat Dec 16, 2017 10:22 pm
by BEKA-BEKA
Can we still use the traction switch if the traction control is used with other standalone ecu? Do you have any suggestions on how to connect them together?
Posted: Sun Dec 17, 2017 8:51 pm
Yes. Connect what together?
Posted: Mon Oct 14, 2019 9:36 am
by dc5itr01
I would also like to connect hondata tc to aftermarket ecu.
This ecu can only cut spark if given a signal as to when it should cut. And it can cut for a predetermined duration.
But it cannot sense any difference between 1v and 5v from hondata tc.
Can the hondata tc perhaps pulse this output in relation to the amount of spark cut required based on slip read?
Or is there another way of this working?
Posted: Mon Oct 14, 2019 9:43 am
No, this is not possible.
Posted: Fri Jan 24, 2020 4:10 pm
by dhrrx7
This system looks intriguing. I have a 2006 S2000 with a Rotrex that runs an AEM Infinity series 5. Will this system work with that ECU?
