2007 acura tl-s wideband
Posted: Mon Sep 25, 2017 6:01 pm
Hey everyone, i have a couple questions in reguard to installing a innovate lc2 wideband in my 07 acura tl-s.
recently recieved my flash pro and chose the innovate wideband for my A/F meter.
Just wanted to be sure that i am going to be doing everything properly setting this up in my car.
once i get everything power and ground setup for my meter i will want to be running the analog signal output to my ELD pin on the ECU?
Remove the pin, and install my signal/output into the location of the removed pin? Will i need to do anthing special to the factory ELD wire besides tape it up? so i need to hook up a relay,switch, and resistor off of the old wire?
once i go into the flashpro manager, what will i want to do to get the proper data from my A/F guage?
thanks,
chris
thanks,
chris
